ALL NEW Lethal Performance Wheel Spacers!!
Wellington, FL, USA
Hey there, #teamlethal fans! NEW PRODUCT ALERT!
Looking to give your Explorer ST that aggressive look without going all in on an aftermarket set of wheels?
Look no further than the all new Lethal Performance Wheel Spacers!
Available in 1", 1.25", and 1.5", these spacers bolt directly onto the stock wheel hub and are designed specifically for the 2020+ Explorer ST’s.
These were tested on the OE Wheels with our Lethal Performance Lowering Springs!
Check them out here --> https://www.lethalperformance.com/info/explorer-st-wheel-spacers
Jetiemann
Houston
Looking to buy some soon. What would make these different/better than other popular wheels spacers on the market?
JakeLethal
Wellington, FL, USA
I would say due to the fact they're crafted from Forged Aluminum T6 6061, our wheel spacers offer superior strength and durability while maintaining a lightweight profile. The use of 12.9 grade hardware guarantees robust and reliable fastening, providing peace of mind under all driving conditions!
These or Bora spacers aren’t going to fail, and like Jake said above the quality is going to be better. FYI to anyone looking for spacers 1” males the wheels flush, anything larger won’t require wheel studs trimming but will poke out of the fender.
New York
2024 Ford Explorer ST
So, if i got the 1inch would it require me to cut the studs? Want to be sure before i ordered.
Yes, like I mentioned above, they require slight trimming, but it’s not that bad.
Combatvet
What's the torque value for these spacers? And do you still torque to the factory wheel to 150 ft lbs?
SmittysST
SOCAL
2023 FORD Explorer ST
Looks like 1" (Cutting req) in the front and 1.25" in the back is pretty flush?
Just get Eibach 30mm spacers. No cutting and it’ll be flush on both ends if you set rear camber to -.5°.
There’s no reason to run different thickness spacers.
I thought 1.25” spacers all around poked a little bit, and 1” spacers all around was flush.
An inch is 25.4mm so 30mm is a tiny difference but it’s enough to clear the studs and still be flush enough on stock 21’s and tires. 295’s will push out some but not as much as with 1.25” spacers which are a couple mm wider. It’s just an in between size that works well.
Combatvet
Crickets!
