Probably a dumb question about winter tires but......
Dozer12
Ottawa, ON, Canada
So my wife picked up a 2020 St with 21inch wheels with Brembo brakes, she needs winter tires and rims but my concern is will 20inch fit even with those huge calipers in it? I have shopped around and not 1 site has mentioned the brakes being an issue so am I to assume there will be no issue? apologies if this topic has been already asked before. Thanks for the help.
Austin, TX, USA
typically a lower wheel offset will give you more brake clearance however wheel design can also play a factor. Www.Willtheyfit.com May help you compare. But to answer your question partially, Going from 21” to 20” alone will not cause issues.
Kelowna, BC, Canada
Where did you get the Brembo's for an ST? I take it you are talking about the Street or Track Pack, which are not Brembo brakes-they are a pretty standard sliding caliper rather than a fixed caliper like higher end braking systems.
Lots of 20" wheels will fit those without worry, even some 18's like the Police Interceptor steelies will fit over the Street/Track pack brakes.
yeah, just get 18" with 255/65/18 winter tires
Burlington, ON, Canada
Fake Brembo’s, aka “Frembos”
NJ
Was wondering where the OP got Brembos as well...
D
Dozer12
Ottawa, ON, Canada
My apologies I just assumed that they were because they are red, I didn't go with her to buy it, thanks for the reply.
Toronto, Ontario, Canada
Give me an hour or 2 & I will send you all my info for my aftermarket winter tires. Hopefully there is a model number for the rimes
D
Dozer12
Ottawa, ON, Canada
Here you go. Price is in Canadian. I went with the Euro tech rimes with the Blizzak tires & tps sensors. The model number is in the left side for the rimes.
Thanks so much.....I found PMC tire.com and their site says I can go to a 18 inch (18x6.5) with the performance brakes so I might do that.
Glad you were able to figure something out. My advice is order it sooner then later, the white stuff is coming very soon lol
Kelowna, BC, Canada
PMC tire has been excellent so far. I have bought 2 sets of tires for my other cars from there and the local shops can't touch them for price.
Sudbury, ON, Canada
I got my rims from canada wheels.ca and they held up my order to verify that I had “red calipers” so they were sure new wheels had clearance.
Sudbury, ON, Canada
I should have added I downsized to 20 inch wheel for winter.
CaseyST
Moncton, NB, Canada
I also ordered from CanadaWheels, they indicate very clearly what will fit and guarantee fitment. I got a set of 18" wheels and they clear the brakes just fine, even though Ford told me it wasn't possible lol. Just got taller tires to accommodate the smaller wheels
Dave G ST
Hurlock, MD, USA
How about TireRack. Have not ordered wheels from them before, but they seem to be knowledgeable and will get you set up properly. I would use 20 inch wheels for a nicer look if you can find a good winter tire to match.
