What are these two things I found?
DJ_USMC
Indianapolis
I recently purchase a used 2021 ST and I absolutely love it. I went through this weekend and changed the oil as well as all filters. I pulled the bottom cover off to get to the drain plug and the yellow plastic piece fell out. It kind of looks like someone tried to super glue it back in but I have no idea where it came from.
Also, I noticed the pictured plug in the OBDII port with two small wires running to it.
Any input is much appreciated!
Illinois, USA
Not sure on the plastic piece but it looks like you've got a gps tracker from the dealer (lo-jack). Seen a lot of those on the forum.
The first one is the cap for a hose clamp screw. The second is a GPS tracker.
D
DJ_USMC
Indianapolis
Very much appreciated. Can I just cut the wires going to the OBDII connector for the GPS tracker?
Just unplug it and do whatever you want with it.
