Interceptor amber DRL's on Explorer St
Bonaire, GA
Did you go to the link that I referenced 5 posts earlier? It turns of the LED DRL strip and uses the turn signals as your DRL... and the turn signals still work. At night, it's just the headlights. To me, that's perfect.
I know we tried a few different "codes" to change and none worked. We got the LED bar off, and finally found where to turn the orange DRLs on when parking/headlights are turned on.
Palm Beach, FL
Explorer ST 2022, Excursion 2000
Anyone know how to reduce the brightness of the Amber DRLs? They're about twice as bright as the interceptor amber DRLs.
Additionally, if someone can figure out how to get "Position" lights to turn off when the blinker is being used, that will fix the blinker issue as well. Similar to how the white DRLs turn off in daytime when the turn signal is active.
Btw, the vehicle uses "Position" light mode as the running lights at night when in auto light mode. That's why the DRLs stop working at night for those who set it to "DRL and Turn"
If there was a "Use DRL at night" option in ForScan, none of this turn signal mess would be an issue haha
cmaybury
Melbourne
2020 Ford Explorer
I've looked it up, but I could be wrong on this, apparently the turn signals are at 100% and cannot change unless you order police interceptor headlights or if someone else has found a way. Will the Ambers DRLs work at night if the positions lamps are off? The position lamps are in the forscan.
Palm Beach, FL
No. You have to have it in "DRL, Turn and Position" for it to work all the time, even at night. If you set it to "DRL and Turn," ambers will not work at night. Essentially, the DRLs switch to Position lights at night when the headlights are on. Even if you turn the headlights on manually, the position lamps also turn on. Turn signals are unable to override the position lights, though.
JiggsST
Worcester MA
I feel like a broken record
For the ambers to run as DRL and work as turn signals during the day (only works during daylight, night time is normal headlights and turn signals, no DRL):
Set the turn lamps as “turn + DRL” or 726-43-01 x1x1 xxxx xxxx
set the DRLs to “no used” or 726-42-01 x0x0 xxxx xxxx
Sorry if this has been asked already but this post is from last June. Is this the same sequence for the 2025's?
Jessup, MD, USA
Is it possible to set the fog light as a turn indicator? I could see that as one potential way to run ambers at night and still have turn signal functionality.
That is not an option. It would be nice if it could be done but the code just isn't there.
Palos Hills, IL
2025 For Explorer St
Wow, still no longer term solution.... lame as hell.
Nightshade
Firefighter
Alberta, Canada
That’s because it’s a hardware issue (headlight), not a software issue.
Combatvet
The real fix is not an easy one, nor cheap. You'd have to find a headlight repair source that will disassemble the entire headlight and then change the LED color on the board in the headlight itself.
Nightshade
Firefighter
Alberta, Canada
JRHII
EMT
New Jersey
Palm Beach, FL
Just wish we had an option in Forscan to "disable Position lights when turn signal in use". That would completely resolve the issue with blinkers not working up front at night.
NJ
2020 Interceptor
Hello All,
can someone help me with precise settings for my 2020 FPIU aka Interceptor for this to work as mine was all turned off prior?
What I want:
During the day and switch in auto mode I want the Ambers to stay lit in park and drive all the time and then when night comes the low beams will come on as expected as the switch is in auto mode.
And if I want to turn this off for any reason I want to either turn the switch to off or use the cluster to turn off DRL in settings.
TIA.
jgorchow
U.S. Coast Guard Veteran
Chicago
2024 ExST
It would be SO cool to change the DRLs that when you switch to sport mode, the DRLs change to red. I know, no can do. Oracle Lighting has kits to change the DRL strips, so it can basically be any color you want, but expensive and you’ll need to open up the light housings. It’d be neat though.
