AKATA wheel spacers
Yenko
Milford, CT
I installed 295/40R21 Conti DWS06 tires and wanted to add wheel spacer but don't want to stick out to far. I was looking into AKATA wheel spacer, for the front 12mm and for the rear 20mm. For the front spacers do I need to install longer wheel studs or wheel it have enough threads on the factory studs and I know I will have to cut the rears?
I'm not familiar with Akata, but I'd stick with the tried and true Bora spacers. 12 mm and 20mm is roughly .5" and 5/6". Both of those won't make the wheels flush. 1" spacers all around with the correct alignment will make the wheels flush. Also, if you're talking about slip on spacers, I wouldn't recommend a slip on spacer that big. With the Bora spacers, they're designed like another hub, so you'll actually need to trim the studs on anything smaller then 1.25" spacers.
Illinois, USA
This is where I went wrong. I didn't realize the trimming was only required on the smaller spacers. Little extra work, not a huge deal. Thanks for that tidbit though.
