2025 Headliner Exposed at Drivers Door
JAX, FL
25 Explorer ST & 21 F150 PB
Recently noticed the headliner at the driver's door showing below the door gasket. Adjusted the gasket down to cover, but it slides back up to its natural position. Dealer thinks the headliner needs to be replaced but doesn't know if it will get resolved until they replace it. Replacing the headliner doesn't seem to be a trivial process.
Has any one seen this issue before ?
It just slipped out from under the rubber. Stick your finger in there and fix it and find a real issue to worry about.
UGADawg96
JAX, FL
What do you mean stick my finger in there and fix it ? It won't stay under like it is supposed to. I've messed with it, the service tech, and the shop manager at the dealer have all tried.
Smack the weather stripping. Sometimes it’s not seated all the way on the pinch weld.
SoySauceSoakedSaltine
South Carolina
Super glue/Gorilla Glue? Sucks to have a 60K car and have so much QA issues. But that's what I would do.
UGADawg96
JAX, FL
It's been removed and reseated, no change. The higher it goes, more headliner appears. Setting it lower hides it, but then it is barely on the pinchweld.
UGADawg96
JAX, FL
Fully seated weather gasket exposes headliner:
Gasket has to be pulled this far down to cover the headliner:
It seems like the headliner is cut wrong or doesn't conform up to fit under gasket.
$60K + and brand new but not a real issue.. WTF. Yeah, its a F'ing issue not many, if any, would just let go.
Blah blah blah…90% of the time it’s just a misalignment and no…not an issue. Take 30 seconds and fix it yourself and go on with your life. Looks like he might be the 10%
California
Get some of your wife's mascara and paint it black then ya won't notice it.:p
Autoworker
Should have been pulled offline and fixed at Chicago Assembly. Another example of the lack of quality control there.
UGADawg96
JAX, FL
The dealer has already fixed misaligned body panels and other loose trim pieces. This is the last item and they've ordered a new headliner. Sucks that we didn't notice these items during test drive and/or delivery inspection. Also sucks that this was in Chicago for two plus months on QA hold and they didn't address any of these issues then. The whole QA hold thing was a joke.
23 Explorer ST
The QA inspectors need to be fired! No excuse for leaving the assembly plant like that.
The dealership should of picked up on all those issues when they did a PDI before selling.
You would be holding the plant and the dealer at a higher standard than they deserve. Expecting others to do their job they are paid to do is an unfortunate dying trend. The old saying that if you want something done right, then do it yourself, has never meant so much than in todays world.
RubenRod1
United states
2025 2explorer st
I just noticed mine is the same way. Tried to fix my self, but just won't go in correctly. Calling dealer Monday to get it fixed
UGADawg96
JAX, FL
UGADawg96
JAX, FL
Thread Starter #17
After two weeks in the shop, picked it up today. They replaced the headliner and the sunroof track. No more gaps over the driver's door nor when closing the sunshade.
They also replaced the left front strut for a clunking noise in addition to shimming a rear trim panel due to it rattling bad.
Man.. I'm pretty sure someone else on here told you to "find a real issue to worry about". It was certainly a real issue to me and with everything they had to do, it deffinately was! Glad is has all been taken care of.
UGADawg96
JAX, FL
Thread Starter #19
work order:
Damn!!! This is EXACTLY WHY you don't let anything go, minor or not. A) Because we expect and demand excellence and we paid for it to be nothing other than that. B) Because something seemingly minor might not be as it appears.
