Disable Auto Start/Stop on 2025 Explorer ST
ExplorerSTLine
Pennsylvania
2025 Explorer ST-Line
#61
Ummmmm.. NO. Autostop Eliminator brand is made in USA and with USA parts - that makes a huge difference. It is MUCH better than 4D Tech. I had a 4D Tech (Only because it was out first for the 25') that lasted less than 2-week and failed. I replaced it with the the Autostop Eliminator that came out shortly afterwards. This is the second time I have purchased and used Autostop Eliminator with no issues....
Ummmm - well, I have had the 4D Tech for over 2 months and it is working just fine. I also used 4D Tech on two other cars with absolutely no problems. I went with 4D Tech because they had one ready and when I contacted Autostop they said they were still working on it with no release date. I simply didn't want to wait.
Now, if you are buying the Autostop because it was made in the USA - I understand completely. I just didn't want to wait until they finally released one.
I have Autostop eliminator on both my ST and F150 and have not have any problems and has worked flawlessly,
#63
I had an ASE on my 21 and when I traded it in for a 23, I took it out of the 21 and put it in my 23, it been 3.5 years and two separate vehicles and it still works.
Sumner County TN
2024 Ranger Raptor
#64
63 posts later, still talking about ASS and whose is better.
Geezus…
ExplorerSTLine
Pennsylvania
#65
Geezus…
Absolutely! It is a great topic to discuss. Hope it goes on for at least a year. :ROFLMAO:
Sumner County TN
2024 Ranger Raptor
#66
LOL, fine by me. Keep talking about each other's ASS. You realize how that sounds right? Typical squid... :p
Milkbone69
San Antonio, TX
I would like the Seatbelt Reminder to be removed also, so annoying
#68
The instructions to turn them off is in the manual.
ExplorerSTLine
Pennsylvania
#70
Save you some time go to Page 51 in the Owners Manual (PDF File).
Note: The driver and front passenger warnings switch off independently. When you perform this procedure for one seating position, do not buckle the other position as this cancels the process.
Read Steps 1-4 before proceeding with the programming procedure.
Make sure that:
• You set the parking brake.
• The transmission is in park (P).
• The ignition is off.
• You close all vehicle doors.
• You unfasten the driver and front passenger seatbelts.
1. Switch the ignition on. Do not start the engine.
2. Immediately start the deactivation or reactivation procedure in Step 3. Once you start Step 3, you must complete the procedure within 30 seconds.
3. For the seating position you are switching off or on, fasten then unfasten the seatbelt four times at a moderate speed, ending in the unfastened state. The seatbelt warning light flashes for confirmation.
This switches the feature off for that seating position if it is currently on. This switches the feature on for that seating position if it is currently off.
JAX, FL
25 Explorer ST & 21 F150 PB
#71
Make sure that:
Does this just get rid of the sounds or also the pop up on the IC ?
ExplorerSTLine
Pennsylvania
#72
Sorry - haven't a clue. I left mine alone. I am sure someone will pipe in with the answer.
NDanecker
NJ
25 Explorer ST
#73
the forscan code works on some 25s and not on others.
i assume :eek: it has something to do with build dates
sport its OFF by default iirc
and in my 23 it shows a line through the A S S at start up then goes away, but in sport its there.?
below is for 2025s
Disable Auto Start/Stop PSCM730-03-01 xxxx xxxx x0xx IPC will have line through start stop icon - In sport mode the switch on center console will illuminate
change the 10th spot to 0
Made this change on 25 St built in March 25 and did not disable ASS. If anyone makes any progress on this please post. I do not want to buy a plug-in module. Thanks.
St. Louis
Has anyone had any luck get Forscan to disable the AS/S on 2025?
NDanecker
NJ
25 Explorer ST
#76
I couldn't get it to work. Ended up buying a plug-in device which was stupid easy to install.
2022 Ford F250 Tremor
#77
Public Service Announcement -
For those who have the Auto Stop Eliminator on their 2025 ST, it appears that Ford pushed an update this week that doesn't fully reboot the system, resulting in the ASE to not work as designed.
I contacted the ASE and they had me disconnect the battery for 10 minutes. After doing this, the ASE works again. I am not associated with ASE, but will vouch that they provide a quality product and have great support!
I litterally just went through this exact same scenario with ASE & my 25' ST a couple of weeks ago. After the battery disconnect for probabubly an hour, all was fine again after that with the ASE.
msrobi
Seffner, FL
A word of warning for the 4D Tech adapter, I bought one of these in September. I installed it and used it for about 3 months with no problem. I started seeing issues with the touch screen not working, remote lock/unlock not working, and the tailgate not able to go up / down. I removed the adapter and all of the issues went away.
Combatvet
4D Tech - No problems since April.
