'25 ST K&N Filter
CGainz
NYC, NY, USA
Does anyone know the part number for the filter for the engine. Autozone has been giving me conflicting info. NOT the cabin filter. I just traded in my '21 and wish I took it out. It brought that engine to life.
Thanks in advance.
Order this filter…it’s much better than anything K&N. But let’s be honest…you’re not going to feel a single things from a drop in filter swap. Buy it for the reusable convenience…it won’t add any power. IMG_4870.jpeg
Thanks in advance.
I’m hoping you saying “it brought the engine to life” is a joke because a drop in filter really isn’t going to do anything. The only aftermarket drop in filter worth its crap is the aFe, of which @UNBROKEN gave you the part number.
C
CGainz
NYC, NY, USA
Not a joke at all. When i swapped the filter, the sound of the engine kinda woke up. When in sport mode. It wasn't quiet like factory. No performance gains of course. It just sounded better. I'll give that aFe a shot. Will also be doing the thermal r&d exhaust this time around as well.
23 Explorer ST
I put an AFE dry filter in mine.
Using an oiled filter could potentially suck oil from the filter down into the turbo especially if you over oil it after cleaning.
Where do you think the oil from the PCV system goes? You could oil that air filter until it’s dripping and it won’t hurt the chargers at all.
23 Explorer ST
I had an AFE oiled filter in my Cummins which sucked oil into the turbo and it wasn’t a pretty sight and definitely shortened the life of that turbo.
Yes the PCV will leak into the turbo some but you’re just adding more oil to it by using an oiled “dripping” filter.
I’ll stick to my dry washable AFE to avoid any potential future issues.
No, the oil in the inducer on your turbo didn’t shorten its life. Sorry….thats not how it works and there’s no way your filter had enough oil on it to do that. I spent way too many years building and racing high performance diesels….I have a little bit of knowledge about that.
Westfield, NJ
I totally agree with you, however, in the past I have seen people having issues with over oiled filters being mounted directly to turbos causing oily gunk to build up on the compressor...
