What tool did you use to remove cover plate behind interior door latch handle ???
Putnam Valley, New York
2025 Ford Explorer
Hi All,
I need to remove my driver's door interior panel in order to install a keypad and plug it into the existing harness inside the door. There is a bolt behind a small black plastic plate behind the interior door latch handle that needs to be removed. I have numerous trim tools and mini screwdrivers, but for the life of me, I cannot get that plastic plate to snap out. What have you used to remove that plastic block off plate ???
Thanks,
RON
I basically just sits there. Just flip it out.
United States of America, Utah Orem
2025 Ford Explorer
Hi All,
Thanks,
RON
Those little covers can be a pain. I usually use a super small plastic trim pick or a tiny flathead wrapped in tape and pry from the bottom edge first. They’re clipped in pretty tight and feel like they’re gonna break before they pop out. On my Ford Explorer ST I had better luck using a flashlight and coming in from the side instead of straight on.
Dunno what car you’re talking about but the ST has two tiny clips that barely even grab. I literally just pulled the handle back and flipped it out with my fingernail. It takes almost no force to pop them off. IMG_0813.jpeg
Right angle pick. There's a U shaped opening for it.
2025 Ford Explorer
Been a while since I pulled mine apart. Those clips really are lighter than they look once you know where to grab it from.
