What is the lug nut torque for the 21 inch wheels
Lecanto, FL, USA
Does anyone know what the torque the Lugnuts to you on the 21 inch wheels? I just got a set of black Lugnuts and want to throw them on.
Thank you
150 ft lbs
Massachusetts
First thing I checked along with tire pressure, oil and lights before I drove it off the lot for the 100 mile maiden voyage home(closest dealer that had star white with moon n tune package). I didn't have them prep it at all, I drove it home with the plastic still on the seats. I detailed it when I got home.
Blackssr
Yep. .....150... I can confirm this as I just looked it up when I put my new wheels on...
I Bleed Ford Blue
23 Rapid Red Explorer ST
Every vehicle in the ford/lincoln lineup that has the larger 14mm wheel studs uses 150 ft lbs for the torque spec on the lug nuts. It doesn't matter what the wheel size is. The torque spec is determined by the stud size not the wheel.
ZRX61
L A, CA, USA
three ugga duggas :)
