Using bluetooth via ST....
Hollywood, FL, USA
Almost every time I use my iPhone via bluetooth, the person on the other line tells me there is an Echo. This happens all the time. Also it's not the best connection. Anyone else have this problem? If so...is there a way of fixing this problem? Thanks!
What SYNC version are you on? 21098 sounds like it has solved that problem.
WarST
Hollywood, FL, USA
Not sure which version...how do I find out?
