Turn signal
Ktaylor8324
Culpeper, Va
2022 Ford ST Explorer
Is it possible to increase the pulse turn signal indicator.
Welcome to the forum and thank you for your service! To answer your question, yes. You can change it using Forscan.
Polizi212
If I may ask a dumb question, what is the pulse turn signal indicator? is this the speed the flasher flash? or would it be duration of flash?
I took it as the number of times the turn signal flashes when you bump the lever.
I did some searching on this and it looks like it's not an option on our generation Explorers.
