SYNC 3 Software Update Question
Ryan8886
Waterford, Michigan
Hi All. I tried posting this question as a reply in a different old thread but couldn’t figure out how to bump the thread up for review. So I’m giving it a shot here. Any thoughts appreciated.
Thanks… I have a ‘22 ST that I purchased used back in September. Knock on wood but for the most part my Sync seems to work fine. Little glitch now and then with switching audio sources but generally livable. I don’t think it’s ever had any software updates since leaving the factory. I’ve kinda followed a few threads on here detailing some of the nightmares after getting updates over time. I’ve been wondering if I should do an update to the current firmware or not?? Any thoughts??
Sync3 version 23188 came out early 2024. You absolutely need to upgrade to that because earlier versions had problems--even some so bad that it made upgrading versions problematic. You can check your version by looking at settings in your Sync. Go to the Ford website and follow instructions to create a Sync upgrade USB stick.
