Steeda Springs and sway bar installed!
Livonia, MI
There is a rattle somewhere in the back. Not sure what yet. Installed by a mechanic at a custom fab shop and everything double checked. Sway bar is not hitting the springs like some have shown. I have a sneaking suspicion that the washers that are on the sway bar, used for powder coating, are tapping the underside. Just my guess. Will post the findings once had.
Also, with the wheel turned all of the way the tire contacts the wheel well fabric/ liner. Enough that it is going to wear a hole, not enough contact that it is moving the wheel well liner per se. It simply touches. AC519B0B-5E3F-4D47-B948-D628A68A4579.jpeg 98710AB9-9AF9-4E88-BDE2-7925A34DA8D0.jpeg 0D43602C-EA1B-47EE-B8A4-F574F87E9A98.jpeg EE0BD7FD-1FE7-437F-BBD0-1B422149A8EB.jpeg AC519B0B-5E3F-4D47-B948-D628A68A4579.jpeg 98710AB9-9AF9-4E88-BDE2-7925A34DA8D0.jpeg 0D43602C-EA1B-47EE-B8A4-F574F87E9A98.jpeg EE0BD7FD-1FE7-437F-BBD0-1B422149A8EB.jpeg AC519B0B-5E3F-4D47-B948-D628A68A4579.jpeg 98710AB9-9AF9-4E88-BDE2-7925A34DA8D0.jpeg EE0BD7FD-1FE7-437F-BBD0-1B422149A8EB.jpeg AC519B0B-5E3F-4D47-B948-D628A68A4579.jpeg 98710AB9-9AF9-4E88-BDE2-7925A34DA8D0.jpeg 0D43602C-EA1B-47EE-B8A4-F574F87E9A98.jpeg EE0BD7FD-1FE7-437F-BBD0-1B422149A8EB.jpeg AC519B0B-5E3F-4D47-B948-D628A68A4579.jpeg 98710AB9-9AF9-4E88-BDE2-7925A34DA8D0.jpeg 0D43602C-EA1B-47EE-B8A4-F574F87E9A98.jpeg EE0BD7FD-1FE7-437F-BBD0-1B422149A8EB.jpeg AC519B0B-5E3F-4D47-B948-D628A68A4579.jpeg 98710AB9-9AF9-4E88-BDE2-7925A34DA8D0.jpeg 0D43602C-EA1B-47EE-B8A4-F574F87E9A98.jpeg EE0BD7FD-1FE7-437F-BBD0-1B422149A8EB.jpeg
Hint: hit edit for your post and select the Full Image option. They’ll post full size...you can’t expand them on a phone the way you did it so I can’t get a good look. lol
What are the wheel and tire specs?
csnapp254
Livonia, MI
Vossen 22x10.5 +32. Pzero 305/40
I think I fixed the image issue. Thank for the heads up.
Tucson, AZ
Looks great!
Lehigh Valley, PA
This color is grabbing my interest. Always a classic.
Looks great.
csnapp254
Livonia, MI
Looks great.
Thank you. You know I see all of the black wheels being used and it doesn’t make sense to me. I understand the wider tire, handling etc…. But if you’re going to change do it all the way. Just my opinion.
Rohana and Ferrada have some nice bronze choices also.
Pittsburgh Pa
Hey how about the more important issue. Did you find the problem with the rattle?
I want to get springs and I came across this thread. Also, you got bigger tires than factory issued. Was that the problem? PS I love how the truck sits though
csnapp254
Livonia, MI
Yes!!! Was driving me insane. It was as simple as the bottom bolt on the linkage that connects to the sway bar. I was under there multiple times checking what I could and nothing was loose enough that I could even remotely move it with my hands. Got it on the lift and put the torque wrench on it and it was way off and turned without effort using a wrench. Quiet as a mouse again. I get complements on the wheels every single day.
Stinger
Active Duty U.S. Navy
Madison, WI, USA
Also, with the wheel turned all of the way the tire contacts the wheel well fabric/ liner. Enough that it is going to wear a hole, not enough contact that it is moving the wheel well liner per se. It simply touches. View attachment 5942 View attachment 5943 View attachment 5944 View attachment 5945 View attachment 5942 View attachment 5943 View attachment 5944 View attachment 5945 View attachment 5942 View attachment 5943 View attachment 5945 View attachment 5942 View attachment 5943 View attachment 5944 View attachment 5945 View attachment 5942 View attachment 5943 View attachment 5944 View attachment 5945 View attachment 5942 View attachment 5943 View attachment 5944 View attachment 5945
I’m looking at Bronze for my metallic blue ST. I’m torn between that and black.
csnapp254
Livonia, MI
I’m looking at Bronze for my metallic blue ST. I’m torn between that and black.[/QUOTE
I spent about 2 months searching for any and every picture of a black SUV with bronze wheels. Do the same. I think a polished/ machined bronze with that blue would look sweet. Triple check though.
csnapp254
Livonia, MI
Fitmentindustries.com and Vossen wheels website has a huge picture gallery that could be helpful.
Stinger
Madison, WI, USA
Thanks. I've looked at those sites and some others. I've come to the opinion that bronze wouldn't look right on my metallic blue since all the trim is black. Blue, bronze and black is too busy for me. If it were all black or all blue then it's money. I had bronze wheels on my all black Audi S5 and always got compliments.
csnapp254
Livonia, MI
Thread Starter #14
None what so ever. Rides like a champ and corners like a Porsche.
Stinger
Madison, WI, USA
That’s good to know. I’m going with the same tire and wheel size but with et 30. I may stay stock or go to Steeda springs. Hopefully the 2mm won’t make a difference either way. I’ll post pics soon.
