Steeda spacers for mustang?
adot580
Pittsburgh, PA
2022 Explorer ST, 2019 Mustang Bullitt
So- I saw someone said they had steeda spacers for mustangs on their ST elsewhere so I decide to look into it. I sent a message to steeda on instagram and they said they’re looking into the compatibility but weren’t sure. I looked on their site and it looked like someone made a comment that they fit 20-22 STs as well.
Anyone know of this or have any experience?
https://www.steeda.com/steeda-s550-...MI9_nEw_K4_AIVlYzICh3DnAD9EAQYASABEgKzJPD_BwE
Gilbert AZ
22 Explorer ST
Don’t see why they wouldn’t work. Center bore is the same on the S550 as the ST at 70.5 and same bolt pattern at 5/114.3.
I Bleed Ford Blue
23 Rapid Red Explorer ST
And they both use the same wheel stud size 14mm
Chayi103
Nj
Did they fit?
Click the link and look at what the APPLICATIONS are.
Even if they didn't give you that info, you can find the S550 Mustang and U625 Explorer share the same bolt pattern and hub diameter so these spacers will fit.
polara
florida
2022 ford explorer st
I installed 1.25 all around and I didn't like the way it looks the front wheels and also didn't like that every time a run over a water puddle it will leave all the water splash all over the front fender and door, so I swapped the front one to 1" and use the mustang wheel lug stud they are shorter that the EXp, now look way better and way less water marks....im temped to try the .75" it might fit without cutting lug studs. I got the spacer front Ebay pretty good quality too and more cheaper too.
