Startup Chime
Suprawill1
Maryland
Is there a way to turn this freakin' thing off? I wouldn't mind under normal circumstances but sometimes it's telling me the hill assist isn't working or the traction control or the adaptive cc etc.
When that happens, it chimes 3 times for each function, including the seat belt and the fact that the TPMS isn't working. I then have to sit through a series of at least 15 chimes, sometimes more.
It's aggravating to say the least.
I understand the TPMS warning but the others happen almost every other day. I would say Chinese torture but it's an American car.
Any help is appreciated! Maybe turning it off is a Ford Pass thing, don't know.
MO
2026 ST AWD
Suprawill1,
Not sure this will work but doesn't the OK button acknowledge the warnings and stop the noise?
HTH.
Suprawill1
Suprawill1
Maryland
Suprawill1,
HTH.
Thanks for the reply!
The OK flags appear consecutively on the instrument cluster for each function. Once you ok one, the next appears and there's no stopping them.
When I determine that it's going to happen, I immediately turn the engine off and open the door to turn off the display but it takes its course no matter what.
SoCal
2025 ST
There isn't any global fix that I know of.
You can definitely disable the seat belt chime with Forscan or using the "buckle unbuckle" method.
https://www.explorerst.org/threads/...xplorer-forescan-not-needed.9135/#post-116558
The other's will probably need to be actually fixed. TPMS is a relatively inexpensive one. Hill assist can be enabled or disabled in settings, but it may not fix the chime.
You can get rid of the seatbelt chime I think via Forscan, but nothing else I believe. Maybe just fix that stuff?
Suprawill1
Suprawill1
Maryland
Thanks for the link!
I was dealing with the TPMS but all the others just compile the problem.
I did attempt a fix on the TPMS but they sent me dead ones. I have yet to follow up on that.
I had already looked for the hill assist in the settings but didn't see it. May have to look deeper.
Suprawill1
Suprawill1
Maryland
From what I've read in past posts, all those pop-ups are due to some central module that needs to be replaced and can be expensive.
I'll have to look into the Forscan option.
