Spc camber bolts. Any good?
Eh69758
Firefighter
Baltimore
Explorer ST
Has any one used these. Are they worth it on h&r springs.
You don’t need camber bolts. There’s more than enough adjustment for any static coil on the market.
E
Eh69758
Firefighter
Baltimore
Explorer ST
I kinda figured as much. I’m going to try out the piu strut so I figured if it helps I’d throw it in. There is a pretty noticeable popping going on and some on center dullness so I’m also replacing end links with the steeda joints.
The front is gonna sit at -.8° give or take .1
That’s perfectly fine and no bolts are needed.
