Recall
Missouri
2025 Ford Explorer ST
Anyone else seen this
Yes, there is a recall for certain 2025 Ford Explorer ST models due to a potential powertrain control module (PCM) issue. The PCM could intermittently reset while driving, potentially causing loss of power, difficulties shifting into park, or even the transmission shifting into park unexpectedly. Car and Driver reports that this recall affects 24,655 2025 Explorers. Ford will be notifying owners via mail beginning in late May, according to CarBuzz.
Elaboration:
  • Recall Details:
    The recall, according to Ford, involves 24,655 2025 Ford Explorers built between December 2023 and September 2024.
  • Issue:
    The PCM software in these vehicles could be faulty, leading to the PCM resetting while driving.
  • Potential Consequences:
    This reset could cause a variety of problems, including a loss of power, difficulty shifting into park, or the transmission unexpectedly shifting into park, potentially damaging the pawl.
  • Remedy:
    Ford will update the PCM software in affected vehicles and inspect the transmission and parking pawl for any damage.
  • Notification:
    Owners will be notified by mail starting in late May,.
  • Affected Models:
    Specifically, the recall affects the 2025 Explorer ST and other 2025 Explorer models with the 2.3-liter EcoBoost engine.
Illinois
Just had this service done 5 minutes ago through the mobile service. Two updates were needed for me. He said the vehicle will need to learn how I drive all over again. The tech said you might feel different shift points than I'm used to but will fix itself over the next two weeks. The updates took about 40 minutes in my driveway through dealership mobile service.
W
Missouri
I do note that this only applies to vehicles made "December 2023 and September 2024" and with the base 2.3-liter EcoBoost engine. I suspect that most ST owners in 2025 have the 3.0 engine.
Chairborne Ranger
I read about a recall Recall 25S35 on another Explorer forum this morning (https://fordauthority.com/2025/04/2025-ford-explorer-recalled-over-powertrain-control-module-issue/). I received a notice from Ford in the mail last week about Customer Satisfaction Program 25B02 advising me to make an appointment to update software on my 2025 ST for the PCM. Now there's a recall for the PCM on select vehicles beyond the CSP? I'm going in on 6 May for my software update and will have to ask the service department if they know about any recall but given that they didn't know about the CSP I'm not expecting to learn much.
Massachusetts
2023 ST
Interesting recall.
I was test driving a 2025 ST about 2 weeks ago, and I recall the vehicle would randomly just shut off on it's own a couple times during the drive. Salesman insisted I was accidentally hitting the push-to-start button on the dash. Riiight.
I wonder if that is related.
Jeppo
Davidson County, NC
Yeah, I keep hitting it with my foot. :ROFLMAO:
Chairborne Ranger
I had my appointment this morning for the 25B02 CSP regarding the PCM software update. Unlike some others who reported it only took ten minutes my dealership managed to take nearly 2.5 hours! To make matters worse the service manager then tells me that they ran some diagnostics and didn't find codes P2C38 or P2C39 indicating an engine over-temperature issue and thus concluded my software did NOT need updating after all so it was kind of a waste of time. The SM seemed to be only vaguely aware of the upcoming PCM related recall 25S35 I mentioned in my previous post so he couldn't share any details on what that will entail.
