Rear stud bolt
Toronto, Ontario, Canada
Anybody have any tips on how to remove a rear stud bolts on a 2020 thank you all in advance
What stud bolts? Like the rear wheel studs?
Line the one you want to remove up with a spot behind the flange that’s clear and whack the shit out of it with a hammer. They pop out easy. Pull the new one in with an open ended lug nut.
F
Ok thank you. Weird question I tried to rotate the tire when I had it off. Do I need both rear tires off the ground to rotate it?
