Rear Bumper LED Reflector replacement
Aceinkc
Kansas City
I purchased the leds to replace the factory reflectors. When trying to install them I got stuck. There is three black wires with white lines that go into a 8 pin connector that connects to the brake light. The turn signal also has two black wires but no connector. The leds have one black (NEG), one WHT (Acc+/DRL), one red (Brake light), and one orange wire (turn signal). I have tried to find a wiring diagram to help but no luck. Can anyone help with what each wire is on the brake lights and turn signa. A wire diagram for me to look at would help. Keep in mind I am an amateur at this and have a basic knowledge of wiring but far from an expert. Thank you for the help.
Cleveland, OH
2025 Explorer ST Vapor Blue
I was able to pin out the ground and running lights for my need. Looking at the pins of vehicle side connector with the latch on top, top left is ground. Top right is running lights.
