Puddle on the tile floor....
Smitau
Memphis, TN, USA
I noticed a small wet spot on the clean tile floor of my garage where my ST usually sits. Ignored it for a day or two. Today I parked in the driveway and low and behold a small slick spot. 2021 5002 miles. Put my finger on the spot... Transmission fluid. I looked under the car and the transmission cross member is wet.. Was going for first oil change, guess it will be a little more complicated.
check out the trans cooler. many have had theirs replaced. you can see it from the driver's door and might be dripping fluid
S
Smitau
Memphis, TN, USA
Thanks, I will look to see if that may be the problem.
