Panic Button
Suprawill1
Maryland
Hi All,
Today, I experienced what I thought was an in pocket press of the panic button so I silenced the ST. A few minutes later, the same happened so I repeated the disable.
When it happened a 3rd time, I thought maybe the button was stuck so I removed the fob battery and used the spare fob. The problem still recurred only more frequently.
I went out to the ST to make sure all the doors were closed but a minute later, it happened again. I then put it through a key cycle to see if something inadvertently stuck
as far as a relay or computer glitch but it happened again a minute later. I was about to take the positive cable off the main battery but it seemed to have stopped.
Anyone else experience this and/or come up with a solution?
Thanks.
Weird!
Suprawill1
Suprawill1
Maryland
