https://www.tunedbyzfgracing.com/pr...eries-carbon-fiber-slip-shaft-for-explorer-st
Key Features
Direct Fitment – Bolts directly to OEM transmission flange and end yoke slips on to differential spline.
Proprietary End Yoke - Custom designed 1350 series pinion end yoke with u-bolts included.
No Adapters Needed/Rubber coupler delete – Built with precision SONNAX aluminum adapter flange with hardware on transmission end for true plug-and-play installation.
Premium Carbon Fiber Construction – 14 layers of multi-directional weave provide exceptional strength and torsional rigidity.
Lightweight 2024 Aluminum Components – Stronger and more durable than traditional 6061 aluminum.
NEAPCO Performance 1350 series U-Joints – Performance-grade, solid cross, non-greaseable design for maximum reliability. Specifically engineered for racing.
High-Speed Balanced & Torque-Tested In House – Ensures smooth operation and proven durability under load.
Designed for strength, precision, and performance, the Gulfcoast Driveshaft 1350 Series Carbon Fiber Slip Shaft is built to handle the power of the twin-turbo Explorer ST. Each unit is crafted with 3” ID x .155” wall carbon fiber tubing (3.31" OD), a 2024 aluminum bondable yoke and spline sleeve assembly, SONNAX 3 bolt adapter flange and NEAPCO 1350 Performance Series solid cross, non-greaseable U-joints.
Every driveshaft is high-speed balanced on our Coetz Balancer, and includes a printed balance verification sheet with your order. We also torque-test every carbon fiber assembly in-house, ensuring a secure bond and reliable performance under high-torque conditions. We’re proud to be one of only three U.S. shops performing in-house torque testing on every carbon fiber driveshaft we build.
Install video!
Sent from my SM-S938U1 using Tapatalk
Key Features
Install video!
- Show All
