Navigation update won't listen to me
Moline, IL, USA
I updated my navigation in November to NA119. Today I tried to use voice command to find a business and every time I said "Find an address" the screen just goes back to the homepage. I tried several different times and phrases with no response. I eventually typed it in by hand. Voice command does work for everything else. Anyone else have these issues or any suggestions? Thanks.
Your nav installation is incomplete, most likely leaving off the voice package. It should reboot twice if I recall. If you do a search of the other forum, you can find instructions to upload just the right files or you can try to reinstall the entire thing.
Possumcat
Moline, IL, USA
Thanks C. I'll check it out.
Possumcat
Moline, IL, USA
Downloaded the update again, and with much patience, I waited till it was done. "You may now unplug flash drive". I have voice command again. Thanks Cbubya.
