MAP sensor location on the ST
shawnp18252
Tamaqua, Pennsylvania
2021 FORD EXPLORER ST
Can someone tell me the location of the map senor
CONNECTICUT
2020 EXPLORER ST
One on the top of intake manifold and one on driver side intercooler
S
shawnp18252
So there is Two? Would you have a photo showing them? I would appreciate it!
CONNECTICUT
2020 EXPLORER ST
Yeah no problem will be later today or tomorrow
FORZDA3
Gloucester, VA, USA
The one at the intercooler measures Throttle Inlet Pressure and the one on the manifold measures the true Manifold Absolute Pressure.
CONNECTICUT
2020 EXPLORER ST
Same sensor on both. If you upgrade or get the wrong pins your vehicle will struggle to run. If you are upgrading the truck, go with the 4 pins . And notify your tuner
