Knock Sensors Location?
20 Platinum
Was wondering if anyone knew or could point me to the right direction on where the knock sensors are located? Making runs, I keep noticing the knock sensors going up on a WOT run, nearing +4. Happens going above 50, checked the fuel and OAR is at or near -.096 the whole time so dont think its the fuel. It doesnt happen all the time either nor do i hear any actual engine knocking, just dramatic loss of power. Other times it runs great all the way past 100 with no positive knock. NGK plugs are gapped at .028 and have less 2k than miles on them.
My flex pipes do rattle and have read that they can play a part. Only thing left is to change the mid pipes for the lethal one's and/or check the knock sensors, possibly are loose?
Apologies if this has been posted before, I tried searching for it but couldnt find anything on their location
Under the intake manifold.
