Key Phob Battery
Canby, OR
I got a message that the key phob battery was low. I couldn’t find them anywhere so I ordered a couple from Amazon. Changed the battery but still getting the message. Put the second battery in and “still” getting the message! Could there be something wrong or maybe the batteries I bought were bad?
New Hampshire
For me it was bad batteries I got on Amazon, I bought Duracell ones and fixed the problem.
On a similar note I had the same issue in my Z, but that was due to one of the sensors going bad.
I will only use Duracell or Energizer batteries.
Webb City, Missouri
2022 Ford Explorer King Ranch
Make sure you have them oriented correctly. If they are in upside-down, the fob will not work.
Drsobczakst
Chicago
You might have to stick the key fob in the slot that is made if your fob battery is completely dead to " reset the link" if you will. I believe on the explorers its under forward cup holder pad. Just stick it in there and then turn the car on and then remove it.
Not saying this will for sure fix the issue 100% but i know it has helped others before on other fords.....
DaHuntah
Canby, OR
That’s obvious! It starts and displays the message. If the battery was upside down it wouldn’t work at all. I did buy Duracell but they may be bad. I’ll have to get some others.
PA
I just changed the battery on mine the other day. Got the message, swapped the battery. message eliminated. Thankfully there was no need for me to reset.
Rick
Fort Hood, TX, USA
Rapid Red
CR 2450 energizer you can buy them at any Walmart
DaHuntah
Canby, OR
Not the two I went to! Tried Walmart, Target, CVS and Advanced Auto. I’m going to try the Interstate store later.
If you have a ace Hardware check there. Ace stores are pretty good.
DaHuntah
Canby, OR
Ace is the place baby! A bit expensive but they had 'em.
DaveG ST
Hurlock, MD, USA
Both, Family Dollar and Dollar General have these batteries. These stores seem to be everywhere now. Make sure that you have changed the battery in both key fobs. It may be reading the low battery on the other fob.
DaHuntah
Canby, OR
Thread Starter #13
Are you psychic? Changed the battery and still got the message. I changed the battery in my other fob with the one from Amazon and “boom”, no more message! I had no idea it was seeing the other fob. It’s like fifty feet away from my car on the other side of the house! I tried remote starting from there and it worked! I had no idea it reached that far! I usually use the FordPass app. I have to get within about twenty feet to start my truck. Had the car for two years and still learning new stuff!
