How To Prevent Vehicle From Shutting Down?
I'm finally up for having my stereo tuned but, I'm trying to figure out how to prevent the system from shutting down after about 10 minutes. I tried searching and I think I figured it out but want to be sure. Do I need to follow the same procedure for putting it into Brake Service Mode or is there a different procedure?
Edit: Nevermind, I figured it out. It's the same thing. You just need to connect a battery charger while in the tuning process. If anyone else is trying to figure this out, you can view the procedure in post #5 here or you can use Forscan.
