Good evening all, hope all is well
MD
I finally got the rear mirror tilt to working properly on my 2020 Explorer ST, also bambi lights, removed double honk and global windows open and close. Forscan is the best
BMB310
Hello
I was able to get Bambi mode, but played around for hours to get the global close to work. I changed the code per the excel spreadsheet and saved it (didn't work) and also just selected all options to enable global close in forscan (in the BCM, APIM, PDM, and DDM). The global close option displayed on the screen, however, when I went to do it (press lock then press and hold on the fob), nothing happened. Global open works, which is enabled from the factory. When I tried using the windows with the actual window switch after changing the data in forscan they would just roll up or down an inch or so until I replaced everything with the as built data and recalibrated the windows. May I ask what you did to get it working appropriately? I have a 2020 Explorer ST as well.
ButchsExplorerST
MD
I don't hold it to close, just press lock for 3 seconds and release to close, and looks like we have the same settings in forscan
BMB310
Awesome. I'll try that. Thanks!
