Forscan questions (2025ST)
MichaelTM
Missouri
Was looking around in the spreadsheet for the 2025 st and came across these,
7D0-13-03 xxxx xxx* xx-- Launch Control (LC)
7D0-09-03 xxxx xxxx *x-- Lap Timer (LT) • Brake Performance (BP) • Acceleration Timer (AT) • Driver Select Suspension (DSS)
I'm curious about these 2 changes, I have a 25 st and I dont have any of these features and I would like to have them but I dont know if it would work since I've had issues in the past with changing APIM as built files. If anyone has changed these or can test it out and see what it does or I can try it in the next upcoming days and see if anything interesting happens, I don’t know.
Changing those values won’t do anything. They’re set in the programming because they’re on other Ford vehicles, but if the vehicle programming is not set for it you can’t have it.
M
MichaelTM
Missouri
Bummer. Thanks for letting me know I was gonna try changing it tomorrow and seeing if anything happened.
