Ford Connect navigation sound issues
Hi everyone,
I have the Ford Connect and when using Google Maps the navigation sound isn’t working correctly. The volume control while the voice is speaking does nothing. Maps is not muted. You can hear the directions but the volume is about a 2. The settings show the volume at 20. Did the test in map settings and you can adjust the volume just fine. It will be the correct volume for 1 or 2 turns then it’s right back to super low volume. Can use Google Maps with Car Play and it works fine. Any ideas on what is happening or how to fix? Any suggestions would be greatly appreciated. I have a 2025 Explorer ST with Sync 4,
