Just completed the first oil change on the 2021 ST and was surprised to find that the original factory oil filter was and FT4E-6714-AA and not a FL-2062A as listed in the Owners Manual. A little Google searching suggests that the FL-2062A is the updated replacement for the FT4E-6714-AA.
While "similar" the FT4E-6714-AA seems a more robust construction - black plastic retainers at each end along with at least one vertical metal support bar that offers some rigidity, and a very slightly larger diameter. Has anyone else found the FT4E-6714-AA oil filter on their first oil change?
The only other minor difference was in the oil spec which was now API SP. I nearly did use some API SN-Plus that I had on hand but caught the spec change at the last moment.
