Engine cut out?
Canada
Not sure if this is the right way to word it but a couple times doing 120km (60ishmph) down the highway when I floor it instead of dropping a gear and revving and taking off it’s almost like the revs cut out and then I feel the truck shudder a little, then slowly pick up revs and speed again. I made it happen on purpose after the first time so it wasn’t a one time thing.
now if I mat it from a slower speed or already in a higher gear no problem. Kicks down, revs up, takes off. Just when cruising along...
Wish I had a video to show but hard to drive and record when that happened!
almost feels like the truck gulped more than it could handle and choked on something.
also only happened in Sport mode so far..
running 93 tune from Livernoise, SPD downpipes, whipple intercooler, Borla ATAK exhaust.
dolsen
Louisville, KY, USA
Very first thing I would be doing is talking to Livernois.
Something similar happened to me but without the tune. I was getting on an on-ramp to the highway and was getting on the throttle. I felt some stuttering and then there was a loss of power despite throttle depressed--then it slowly increased rpm and speed. weird. It was a one time event. Has not recurred.
SpeedOften
Londonderry, NH, USA
Need to data log and try and recreate.. might have been a misfire / detonation the ecu retarded timing to prevent damage to the engine.
How many miles do you have while tuned?
sleekone
Canada
Sounds about right.
Zalmer
Parker, CO, USA
I'm having the same issue.. I get a shutter when I'm going about 60mph then give it hard pedal. As soon as it gets to about 68mph it gets a hard shudder for a second or two then levels out. I can also feel it at lower speeds in the 30-40mph range when I'm accelerating and decelerating but more subtle and inconsistent.
I have noticed that if I manually downshift the car, it goes away instantly. I'm taking it in to the shop in early September to try and talk to them about it. Hope someone can figure out the issue! I've already had to replace the taillight, mirror and thermostat...
