Cobb Accessport / sync and car updates
New Jersey
2021 explorer st
I had a tune loaded on to my 2021 and I had disabled auto stop start through the Accessport. Worked fantastic. I got in the car it said software update was done and my auto stop start was on again.
Anyone know if the software update kicks out the tune and the stop start? I'll find out when I get home and get the Accessport out. Just curious if anyone on here knew. Thanks!
Polizi212
I would assume any over the air updates to the system would set that back to its configured setting.
Seattle, WA
I have this happen to me all the time… not sure what the culprit is, but the over the air updates makes some sense since there’s no other reason it should be happening. @GooseTuned may have some insight?
New Mexico
The auto start stop settings are saved in keep alive memeory. That memory can be flushed by the car. So if it gets flushed then the settings will go away
Cobb is working on a fix to keep those settings permanent
Robsdadtruck
New Jersey
2021 explorer st
Thanks goose. I got the plug in adaptor from auto stop start delete .com or whatever it is. Works perfect. Took 2 minutes to install.
New Mexico
Oh good!! Perfect!!
