Climate in SYNC
CoastieN70
U.S. Coast Guard Veteran
Travelers Rest, SC, USA
My Mustang GT and previously owned Ranger and Explorer Sport all were able to access climate in SYNC.
My ST doesn't!
Am I missing something?
Duh... well yeah I miss not being able to access climate in SYNC...
Garland, TX, USA
You have to press the menu button located in the area where you adjust the temps/rear defrost. When you press menu it brings it up on the SYNC screen.
CoastieN70
CoastieN70
Thanks, I found that BUT I still can not control CLIMATE functions from SYNC Voice Control.
i.e. I press the voice button and say "set temperature to 71 degrees" and SYNC responds and then sets the temperature to 71 degrees.
I can do that in my Mustang and I could do that in my previously owner Explorer Sport and 2019 Ranger...
BTW, Thanks for your response... :)
Swaggy
Dartmouth, NS, Canada
I have similar problem with my 2020 ST. My dealership says the ST does not have voice command for climate in Sync 3 although the owners manual states it should. My previous Lincoln MKX had Sync 3 and climate voice command worked fine.
Colorado Springs, CO, USA
Yeah, I miss the Climate Control option in the display. Why would you give a bigger display and then remove an option.
KegsBdry
WashDC
To make room for the bigger display, they had to remove some features. :unsure:
