Anyone order rims and tires from PMC tire.com? $88 a rim for 18 inch and says it will fit our performance brakes?
Dozer12
Ottawa, ON, Canada
Not affiliated with them just curious if anyone has used them before.
GBVx
Washington D.C., DC, USA
This might go better if you actually link the rims in question...
based on your other post, are you really trying to put a 6.5" wide rim on your truck??? that seems ummmm... not ideal.
D
Dozer12
Ottawa, ON, Canada
Kelowna, BC, Canada
That is going to tuck in a lot. I have a set of 20x10's for winter with a 40mm offset and although they come out a bit more than the stock 21's, they still need about 7-10 mm less of offset to be flush.
With a 6.5" wide wheel and that much offset, you might need to check clearance on the inside.
Grimsby, ON, Canada
PMC has a wheel configurator, that you can see what fits by vehicle. If you use that, it will give you all your options.
