Android Auto - Incoming Calls - No Audio both directions
Evansville, IN, USA
2020 ST - Android Auto
Outgoing calls from the car work flawlessly. All incoming calls I am able to answer without issue but there is no audio in the vehicle and the end user can not hear anything. I have tried with a Pixel 3 XL and Pixel 4 XL. Reset the radio to factory (I assume used the on screen menu to reset). So I know for certain its not a microphone issue or anything else due to outgoing calls work fine. Any thoughts or ideas of what I can try?
Calgary, AB, Canada
Mine does the same thing, it's super annoying... I've been through the settings page 1000 times and I can't find the problem
T
Evansville, IN, USA
To add I have ensured all software on my phone and vehicle are on the latest.
Wylie, TX
Yep, I have the same problem.
T
Evansville, IN, USA
So no resolution for you all? I would totally get it if it didnt work both ways there was a hardware issue but seeing is how this is one way it most definitely a software issue. Either of you taken it to the dealer?
Wylie, TX
I've been waiting for a dealership "loaner car" to become available because I'm already going to have to leave it with them to fix a problem with my liftgate not closing.
T
Evansville, IN, USA
If they find a resolution to the call issue please let me know. One of our explorers has been at the dealer for what feels like forever. Really hesitant to take mine in but might if we ever get the other back.
Wes
Austin, TX, USA
Go into the phone settings on the car and turn off the car's ringer for incoming calls. Should fix it.
T
Evansville, IN, USA
OMG. How flipping dumb. Turn off the cars ring tone or set it to use the phones ring tone and it works!!! THANK YOU!!
Colorado Springs, CO, USA
So you have to turn off the car's ring tone and the calls work properly? Why have they connected those for the calls to work properly?
T
Evansville, IN, USA
Phone connected to bluetooth only. Go into the phone settings / ring tones. Turn it either off or to use phone ring tone. Reconnect to Android Auto. Phone calls work perfectly. Prior to this info only outgoing calls had audio. Stupid bug that has been around for a long time apparently according to Youtube. Wes is a life saver. This was my only real complaint about the car so far.
Thank you. I guess the problem exists for iphones as well? I will give that a try with my iphone.
T
Evansville, IN, USA
Thread Starter #13
I am not sure only seen reports for Android Auto. Takes 30 seconds. Please give it a try and let everyone know. Hopefully help someone in the future.
Ok, tried it today and it works flawlessly. I have only used it for outgoing calls till now, today after checking the settings as per your recommendation, I found that it was already set to the "use phone ringtone" option. I got an incoming call as well and it work as expected. Only one observation, the ringtone only rings once and the via the car audio and then stops (no more ringtone). Not a complaint, I am in the car and there is no way I will miss the ring (even if only once) so just an observation with the iphone connected via bluetooth.
Wes
Austin, TX, USA
I had the same problem on delivery. Ford couldn't help me. Dealer was unable to help. Finally found it buried in some Android forum somewhere and it fixed it. You'd think they'd do a better job of getting this out there.
T
Evansville, IN, USA
Thread Starter #16
Spoke with the service manager. Sent them a message before your extremely helpful tip. He called after you assisted in fixing the issue. I asked if he heard about the issue. He said they had no idea but could run some diagnostics and ensure its all up to date. I said no thanks and shared your info.
Wes
Austin, TX, USA
It's really frustrating how the dealers are completely inept with the tech side of the cars. I find better information in these forums. Although I think I found this solution buried somewhere in an Android forum.
Ashburn, VA
I am sure it is in the owners manual - NOT. The documentation is pretty half assed IMHO. And I thought my Toyota manual was not detailed until I saw this one.
Ghaleon4
Oklahoma City, OK, USA
Just used this thread to fix the problem on my end! Thank you so much!!!
2016 Focus ST /w Note 20 Ultra
