Adjustable Rear Toe Links
Didn’t know they had them out. FenFab is working on non-adjustable ones as well.
schaggatron
Iowa
Cool, I'll definitely be taking a look at the FenFab ones too. I wonder if you actually need an alignment post-install, especially if you match the exact length of the factory ones.
I would think not as long as you matched them exactly. A couple of long bolts would make that part easy.
If you can set them to the same length and the alignment is in spec it will still be in spec.
schaggatron
Iowa
Apologize if someone has already posted this, but I saw this on the Facebook group. The FenFab HD Toe Arm:
Brett has made them from tubing as well. Not sure which version will be sold but I’m on the list for one of the first sets out the door.
schaggatron
Iowa
forgot to add it’ll be $275 shipped & powder coated in the red, blue, and black. I’d imagine similar to his other offerings like the charge pipe.
