21" Tire As Built Forscan Codes?
Anyone with 21" tires on their ST and FORScan share some values for me? I'm looking for the As Built config numbers for 726-15-01 and 726-15-02. Mine are:
726-15-01: C104 0166 0978
726-15-02: 4905 0193
Open FORScan
Configuration and Programming
Run BdyCM Module Configuration (AS BUILT Format). DO NOT CHANGE ANYTHING HERE!
Scroll down to 726-15
Also, can you check the tire size in mm?
Run BdyCM Module Configuration (not the as built format)
Search "Tire" and click on "Tire Circumfrence, mm"
should be 2377mm ????
thank you!
South Bend, IN, USA
2021 ST with 21" wheels:
726-15-02: 4905 0190
Tire Circumference: 2374
Pirelli Scorpion Zero 275/45-R21 110W tires
