21 Rapid Red ST - new owner
Kentucky
21 ST high performance
Hey everyone. Traded my 17 Silverado z71 for a 21 Explorer ST with the high performance pack. I plan on keeping it mostly stock since I favor reliability above performance. I plan on searching in this forum for info, but here are some of the items I’m interested in now: -I have 21” wheels, what are the best tires to get? I live in KY, so all 4 seasons here. I favor a good ride and low noise. Tire rack is recommending Pirelli Weatheractive. Anyone have those? -How can I tell if my ST has any kind of tune? -I can tell the exhaust pipe from the engine bay has been replaced. Carfax said the dealer replaced the catalytic converter. Is that what I’m seeing or is that aftermarket down tubes? -recently found the passenger rear footwell has been damp under the floor mat. Not a lot, but enough to get musty. I am assuming this is a clogged sunroof drain. Anyone had this? Where is the drain line? Like I said, I plan on researching for answers, but if anyone had experience with any of these, I would appreciate pointing me in the right direction. Thanks!
23 Explorer ST
Welcome and congrats!!
Check the drain holes in that tray above the battery. They are notorious to get clogged and soak the floor.
2023 Explorer ST, Rapid Red
HTinstaller
Kentucky
Will do. Would that be for the rear passenger footwell or the front passenger footwell?
23 Explorer ST
I misread your post. I was thinking front passenger. Sorry about that.
If you have wet floors second row it could be the sunroof drains.
I believe the drains exit just behind the rear tires somewhere.
If you have wet floors in the back near the hatch I think there was a TSB awhile back on those rubber grommet’s for the wire harness on the hatch that leaked water.
Welcome to the forum.
HTinstaller
Kentucky
Follow up to the question about tires. FYI just found out Michelin CrossClimate 3 are coming out soon. They are supposedly longer lasting and quieter while still having good grip. I will probably wait for those. Still open to hear thoughts!
-Tires: Pirelli Weatheractives are great tires! Michelin Pilot Sport All Season 4s and Continental DWS06 are good too
-Tune: As far as if its tuned, you can see if it shows what gear the cars in in between the cluster
-Downpipes: Yes those would be the downpipes
-Sunroof: Yes that is a clogged sunroof, check the drainage tubes
HTinstaller
Kentucky
Thank you for the info!
Any idea where the drain tubes are? I assume in the b pillar since it’s leaking in the rear floorboard
The drains on a 2020 Ford Explorer ST are located in the front corners of the sunroof tray, running down through the A-pillars and exiting near the front fenders. There are also rear drains that route through the C-pillars and exit near the rear wheel wells.
HTinstaller
Kentucky
Thank you, appreciate it
Welcome aboard!
HTinstaller
Kentucky
Thread Starter #12
I started with cleaning and basic inspection of the moonroof. Found a pack of Smarties candy in the drivers side front corner! Probably not my issue since it was the opposite side floorboard. But it sure wasn’t helping!
