2025 ST sound system build
Snarl
Tennessee
Waiting for NAV-TV to release a Zen module for the 25+ Explorer ST, and not knowing how long that would be, I installed Infinity Reference components front and rear with 2" Kappa mids up front (all factory locations with full sound deadening), then disconnected the center dash speaker. That lowered the sound stage a little but improved separation a lot, and was a HUGE improvment from stock. Adding a simple sub upgrade would make a great system for most.
However, NAV-TV just released the ZEN-F25 module for the 25 Explorer B&O's, and should be here in about a week. Then I"ll be going a little crazy heading down what may be a very deep rabbit hole.
@UNBROKEN . . Move over! This will be an SQ system, but not intending to compete beyond local. I will be updating as the build progresses, good and bad, to help others who also like rabbit holes.
ST_Marshal
South Carolina
Hey Snarl. Hoping you might could educate me a bit. To preface my question, it should be known that my background in audio is the equivalent to a wet carrot.
Alright here goes:
I am looking to add an amp and subwoofer to my vehicle. I did some basic research and determined that I "needed" to buy the PlugNPlay Harness Kit from Plugnplaykits.com. So that's what I did.
https://plugnplaykits.com/collectio...020-ford-f150-with-b-o-plug-play-harness-kits
However, I just stumbled across your post and looked into the referenced product.
Could you tell me the main differences between the two? Which would be better for my intended purpose? Does the Zen module, by replacing the factory amp, make the B&O system sound better, without the addition of anything further?
Alright here goes:
You would use the Zen to replace the B&O system. At a minimum, aftermarket amps are required.
ST_Marshal
South Carolina
So the Zen would be most beneficial for someone who is looking to replace most, if not all the speakers in the B&O system?
I have purchased my sub and an amp along with the above referenced harness kit.
I think I just have to figure out how to go about getting someone to make a custom enclosure for the spare tire/cargo area. Are there blueprints that exist for this? lol
Amazing build by the way. I have not been on here long, but long enough to see that you are someone who has made significant contributions in this community. So thank you for that and thank you for continuing to address newbie questions!
S
Snarl
Tennessee
A lot depends on your goal. So far, I applied sound deadener in the doors and installed Infinity Reference components with Kappa mids waiting for the Zen to be released. Thats actually very good for most people, and a lot cleaner (and louder) than factory. If you want something that rivals your home stereo, you need to start over. The Zen module is used to convert the factory preamp signal to a flat signal with no factory EQ or time alignment. It also eliminates the B&O amplifier, so you must install all new amps.
I will update with photos soon, but so far all I acomplished on the new build (I thought retired meant I would have more time!) was running (2) 1/0 wires through the firewall to the rear, and built a concept subwoofer. It's an opposing dual 8" subbox between the second row captains seats. Opposing to reduce vibrations so it can be used as a center console. I may run into standing wave issues, so it's just experimental for now.
Unbroken will easily keep the SQ crown, since my build is only intended to show what can be done for sound quality without going competition crazy. For now, it will be all factory speaker locations, and hopefully inspire others to start their own builds. The front stage will be phase 2.
S
Snarl
Tennessee
A few pictures from the build so far . .
Front door 6x9 and rear door 6.5 locations (6x9 shown). The basket must be removed for the magnet to fit. Dremel works well. Factory is real small and shallow.
S
Snarl
Tennessee
OEM tweeters are larger than Infinity's, so I 3d printed an adapter. Here is one installed for rear door. 20250917_151421a.jpg
S
Snarl
Tennessee
If you have the sunroof, there are no available grommets through the firewall. However, drilling 2 1" holes for 1/0 wire (1 positive, 1 ground) was easy enough. Remove the cover over the battery, and the holes can be drilled as shown. Make sure the holes are far enough left of the cabin filter since the framework on the inside is larger than the opening. An 1/8 inch to the right and mine would not have fit.
Combatvet
Not to hijack this thread, if I wanted to add something like an 8" or 10" Bazooka tube, what would I need to accomplish this task? TIA
S
Snarl
Tennessee
And the sub box experiment . . I have done opposing subs for inside before, but never for a car. This one is using 2 Skar VD-8's (I know, not SQ!, but what I already had). The concept is both subs (one front, one back) move in the same direction, out together, in together, to cancel the vibrations. "IF" it works, it will be a good future center console. This box is .7 cu ft sealed net volume, but size would be determined by the subs used.
S
Snarl
Tennessee
@Combatvet; The easiest way is to replace the factory sub using a harness like the "PlugNPlay" listed in a previous post and a monoblock amp.
S
Snarl
Tennessee
Thread Starter #12
To replace speakers, just swap em'. No ZEN module needed. But just the front stage is all that's really needed. The rest can stay OEM. I removed the center dash completely, but thats personal taste. To install a subwoofer replacement, the harness taps signal from the left rear? I believe.
The Zen isn't needed for that either. To replace the amplifiers, add a DSP, jump down a rabbit hole, etc. then the ZEN is needed.
ST_Marshal
South Carolina
Thank you for sharing your build thus far and enlightening me on the subject.
Phoenix, AZ USA
'25 Expl. ST, Rapid Red
Wow...GREAT idea; TYVM.. Probably will do something like that for my '25; we'll see what my caraudio expert thinks.. Pls let me know where to send my $1 licensing fee. :)
Am thinking of four side-firing 7" woofers.
