2025 Rear Tailgate Light bar Parking lights
72-C10
Raleigh, NC
2025 ST
Hello- Does anyone know if the parking lights can be turned off/disabled on the new light bar that is on the lift gates on the 2025 ST's? They are only on when the parking lights are on. Do not activate with the brake lights.
Is there a way to maybe turn off with the FORScan?
23 Explorer ST
Maybe unplug them from the back?
I don’t know if that would give you a warning or not.
Curious, Why do you want them turned off?
72-C10
Raleigh, NC
2025 ST
I thought about unplugging but I'm fairly certain I will get a warning message. Just not really liking the look is the only reason.
23 Explorer ST
I guess you could try it and see if a warning pops up?
If it doesn’t, make sure you cover the connectors to keep the plugs ends from corrosion.
