2023 Explorer ST Build
Darkknight23
Los Angeles, CA
23 Explorer ST
What's up everyone!
Finally decided to start a proper build thread after the short intro.
02/22/26 – 38,654 Miles
Installed a Mishimoto Oil Catch Can today. The install was quick and straightforward overall.
I did run into a small issue with the right-side M6 nut clip. The radiator mounting location on that side was slightly thicker than the left, so it didn’t seat exactly the same. It still worked fine in the end — just something interesting I noticed during install.
To protect the hoses from rubbing and heat exposure, I added expandable nylon sleeving (3/4"–1") from AlexTech (ordered from Amazon). It gives everything a cleaner look and adds some extra peace of mind.
⚠️ If you plan on using expandable sleeving:
Do NOT use scissors to cut it. It will fray instantly.
Use a hot knife instead. I picked one up from Harbor Freight for $24.99 and it made a huge difference.
Really happy with how it turned out.
