2020 Ford Explorer ST breaks problem after changed
Mart
Canada
2020 Ford explorer ST
Hi community, I did set the service mode to change my rear brakes and disable the after mode. I left the vehicle to change it sideways, to change my brakes forward. No error code, everything's fine. After changing the front brakes, I left the vehicle to move forward and brake. Error codes appeared in the dash. All driving aids in error as well as a message to have the rear brake system checked. However, when I activate the handbrake, it works on both wheels. So my rear brake on the driver's side doesn't brake at all, and the front brake on the passenger's side doesn't brake either.
I've turned the service mode on and off several times, but it doesn't solve the problem.
Anyone have a solution...thanks!
Q
Translated with DeepL.com (free version)
Toronto, Ontario, Canada
Drive your car for about 10 mins & you should be fine. The system might have to relearn the e brake position.
