Trailer Brake Controller Plug Location, and Redarc Install
Draco-REX
OH
I installed a Redarc trailer brake controller the other day. And in researching, I found the explanations of where to find the plug in the car to be lacking (and ultimately incorrect). So I figured I'd make a post about it to help others in the future. I have a 2021 Explorer ST, I do not know if there are differences with other years.
The most common explanation of where to find the plug is "by your right knee" which was way off and would have led me to searching behind the center waterfall or by the column. I've also read that it was "taped to something" to hide it out of the way. I found both to be incorrect.
Finding the socket for the trailer brake control harness.
First step, remove the lower dash panel and the kick panel above the pedals. There is one visible 7mm bolt by the driver's knee, and another hidden behind the fuse panel cover. By the pedals there's a 10mm nut against the firewall and a 10mm bolt going towards the trans tunnel. Finally there's a christmas tree fastener right below where you removed the first bolt. Pop the lower dash panel free and work the kick panel out. There are two wires connected to the panels, one for a light above the pedals and the other for the OBD-II port.
Disconnect the plug for the lamp, and use a flat screwdriver to release one of the tabs holding the OBD-II port into the bracket and it'll pop right out. Put the panel aside.
If you stick your head under there, or a mirror/camera, you'll find the plug for a trailer brake controller right above the brake pedal behind the knee air bag and floor vents.
It's the big grey plug in the picture. It's mounted to a cross bar there, you don't need to remove it. You'll also see that there's a dummy plug in the socket. Push back the angled tab you see and pull out the dummy plug.
The dummy plug.
Now you can plug in your trailer brake controller harness and proceed with the install.
Installing the Redarc Tow-Pro (Liberty or Elite).
I went with the Liberty over the Elite because I don't plan to tow off-road, and the Liberty still allows me to manually trigger moderate braking to reduce sway if needed. But both versions are identical dimensionally so this install will work with either.
Plugged in the harness:
Secured to the column harness:
Then I coiled the excess, connected it to the Tow-Pro. I also connected the cable for the control knob and then mounted the Tow-Pro with 3M rivet tape to the top of the knee air bag. The bag expands from the bottom, so this won't interfere with deployment.
Now to mount the control knob. I got the idea of where to mount it from the Bronco forums. It looks like Ford offeres an accessory trailer brake controller for the Bronco that is just a rebranded Redarc Tow-Pro Elite. They mount the knob in with the headlight controls and it looks really good. So I decided to mount mine the same way.
First, pop-out the lighting controls. It's really easy, just stick your hand up behind it and a light push will pop the panel out.
Now, at this point I thought I had pictures of the next stage, but I don't. Fortunately it's really easy to figure out. Unplug the switch assembly and look at the back. You'll see that there is room for the control knob to fit. Just mark and make your holes per the instructions and you'll end up with this:
Back side
Front side
And then put everything back together.
Finished product:
I hope this helps someone in the future. It wasn't difficult to do and only took me about an hour or so.
Thanks for reading.
Nice write up.
Round Lake, IL USA
Amazing write up, thought I would need this and my BIL ended up using his truck. Always fun to take an opportunity to modify the ST! Thank you for this.
De_Stiller1948
Tennessee
I have removed the two screws and the two 10mm fasrners, the ones near the firewall and the transmission tunnel but can't get the panel off. I'm afraid to pull on it hard for fear of breaking it. Just how hard is it to pull it away from the plastic clips. I see no difference between your ST and my 23 St.
D
Draco-REX
OH
The panel takes a bit of force to pop free. Start at one of the upper corners and tug straight back towards the driver's seat, not downwards.
De_Stiller1948
Tennessee
Thank you sir, that worked like a charm. I was too " skert " as we hillbillies say, to pull on it. Now to find that dam plug. Why would Ford bury it in a mass of cables on a vehicle ordered with towing package. Have not found it yet but at least I'm making progress. Again, thank you for your assistance and for the post. I'm using the exact same controller as you did. Your installation looks great.
D
Draco-REX
OH
It wasn't buried at all on my car. Slide your hand under the knee air bag and you'll feel the plastic vents and right behind is the plug. My second picture is looking straight up from the floor mat. If you sit in the driver's seat and put your foot on the brake pedal, your toes are pointing straight at the plug.
De_Stiller1948
Tennessee
Found it my friend, exactly where your picture showed. Never got that inner piece of trim that fixes to the Trans tunnel and firewall off. That corner on the right end of the air bag just fought me until I gave up on removing it. I was able to pull it down enough to get the plug loose but not without sacrifice of some 76 year old skin and blood. Plugged my harness in and stopped for today to heal and try to get back on the good side of my Savior. Will hopefully finish tomorrow. Your post is spot on for installation of the Redarc controller for a 2023 Explorer ST. Thank you sir for the help.
D
Draco-REX
OH
No problem. I'm glad I could help. I'm sorry I don't have pictures of the switch install. But I found it easier to drill the large hole from the back so I could be sure the switch would fit, then the small hole from the front so I could be sure it was straight.
Howie
Western ma.
2021explorer
Thank you thank you and big thanks! That made it almost easy !
Texas Hill Country
2021 Carbonized Gray Explorer ST
This was very helpful. Thanks for taking the time to write it up. I almost pulled the trigger on the same controller and was going to mount the knob exactly like you did. I decided to go with the more basic Curt TriFlex and just used doublesided tape to mount it to the lower dash. The controller can unclip from the mount and the plug is accessible so I can just remove it when I don't need it. Pretty easy install.
kimmonia
Midwest
Thanks for the write up! Inspired, I have the same controller for my jeep. Now I know where to put it for my ST
powerboatr
The dummy plug.
Back side
Front side
Finished product:
Thanks for reading.
excellent
you should post this on e trailer as a install pics
thank you
Pine59
:Minnesota
2023 Ford Explorer
Just a quick thank-you for your really helpful posting. Although I drive a 2023 Explorer XLT, this was really helpful, especially for finding my way around the dash panels and install. Without much experience it took me about 5 hours instead of 1, but was being super careful to prevent any permanent flaws in the dash. Install went great, looks great, thanks again.
