Looking for BOV Dual-Port for 2023 Ford Explorer ST
aljazaf
Kuwait
I wanted to ask if the there is BOV Dual Port that would fit the 2023 Ford Explorer ST? I am in need of a BOV with Dual Port functionality that operates similar to the stock electronic blow-off valve, venting pressure into the intake at low rpm and to the atmosphere at high rpm.
A
aljazaf
Kuwait
Appreciate your help! I'm just a bit confused about the Ford Explorer not having a BOV !then how does it reduce pressure in the intake system as the throttle is closed to prevent compressor surge.? Also, would adding a Fen Fabrication BOV get noticed by the manufacturer? I really don't want to void my warranty! Thanks for any insights you can provide .
Bear, DE, USA
I
on late 2021 and on ford is managing turbo pressure through the ecu engine parameters and turbo waste gates instead of a dedicated BOV
A
aljazaf
Kuwait
The 2023 has no such thing. It was eliminated a couple of years ago.
If you want to add a BOV for fun check out www.fenfabrication.com
i didn’t understand what you mean to add BOV for fun ! Can i add BOV on 2023 Ford Explorer ST to get the whoosh sound ? And if so what should i look for ! Thanks
I literally posted the link for where to go.
A
aljazaf
Kuwait
gafool25
EMT
georgia
2023 explorer ST
wow just saw this i wish i had read it before i orderered to bov from boomba! lol oh well
