I really hate it when…
I can’t get the tire pressures to all match.
NYC
86 degree outside temp is also a bit too warm.
I can relate being somewhat OCD. Also this vehicle had 3 flats in 2 years, only one could be repaired when new. I've had new tires less than 2 months and got another flat last weekend. Really bad luck! I feel like I need to buy 8 tires and store the extras in my shed. I'm getting paranoid! LMAO Damn were you really going 150 MPH? I've only gotten mine past 3 digits.
Autoworker
And he's only in 9th gear. Wait until he hits 10th.
20 Platinum
And at 71+k miles.
Good to see it still running really strong.
At WOT they’ll hit 150 in 7th. I just eased it up to 150 out of boredom.
Gurnee, IL
Is this the recommended pressure for 21" tires?
Dealer I bought my used ST from had them set at 33 all around.
21’s should have 33
Columbus, MT, USA
The real question - are you going 151 or 152?
Jeppo
Davidson County, NC
21’s should have 33
Of course, 33 is “cold”. Running 150mph in 86 degree weather will increase the pressure significantly. ;)
Not really. I run 36 cold. Not like it was a sustained run…maybe a couple miles at most.
