E85
Skunk Hollow
If I convert to E85, what do I use when I'm in an area that does not have E85 and need fuel ?
Marinette, WI, USA
You would need to change back to a pump gas tune.
M
Skunk Hollow
Thank you. There are not a lot of E85 stations out west where I vacation. IE: Death Valley, CA. I guess I'll stick with my current setup of 89/93 oct. At least I can switch on the fly.
LokiWolf
Henrico, VA
89-93 would be a tune change...? Same as E85 to 93.
Plus for E85 you need a Pump. I switch from E50 to 93 regularly. Just pump, and while pumping change the tune.
Sent from my iPad using Tapatalk Pro
M
Skunk Hollow
Thank you. Good to know. Guess I'll hit up my tuner for a cost estimate.
LokiWolf
Henrico, VA
Who’s your Tuner? Just curious.
