How to stop Speed Limit icon from blinking
JohnE
Vancouver, WA, USA
There has to be away to override the over speed limit warning, right? I haven’t found anything in the OM.
Portland, OR, USA
You can shut it off in the settings via the touch screen. I don't remember exactly where in the settings but I did see the option to disable it.
Portland, OR, USA
It's an option in settings "Driver Assistance/speed sign recognition" or something like that
JohnE
JohnE
Vancouver, WA, USA
Thanks I found it, just where you said. I swear I looked there before. That speed warning was driving me crazy!
Surprise, AZ, USA
Funny, I just turned mine off from flashing the other day. Was really starting to bother me.
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
My wife LOVE's that flashing Speed Limit warning, but I too turned it off.
CapTom
Anderson, SC, USA
Mine doesn't give me access to shut it off, but this morning it stopped flashing all by itself.
Hudson, MA, USA
If you set your "tolerance" to +5 mph and the speed limit sign says 50, if you are doing 55, no flash. Push it to 56 and it flashes until you're under the Speed Limit Sign +/- your tolerance setting.
PJ
JohnE
JohnE
Vancouver, WA, USA
PJ
The Tolerance setting is for intelligent cruise control. If you have the Tolerance set to +5 and you have your cruise set for 5 over the speed limit, when the system detects a speed limit sign change, it’ll change your speed to 5 over whatever the changed speed limit is. The icon will blink if you set your cruise above what your Tolerance is set for too. There’s another setting for “Speed Warning” that can be turned off that takes care of the blinking icon when not using cruise control. That was the one that was bugging me.
Demarad1
Windsor, ON, Canada
Can you elaborate on what you did? Having a hard time finding that toggle to shut that off. Thx :)
