P3 gauge in 2025 - 2026 installation help
Minnesota
2026 ST
Hi guys - I've searched high and low and Grok confirmed it can't find a video or post anywhere showing the installation of the P3 gauge in a 2025 or 2026. I'm getting ready to install mine and don't want to just start prying on things without some knowledge. I've watched HSF's videos and while very helpful (not sure if Travis is on here but he's a hell of an asset for our community) it doesn't fully apply to a '25-'26.
Hoping someone here has installed a P3 on a '25 or '26 and can give me a couple pointers.
The first 2 trim pieces are easy. Based on the photo below, I'm guessing I next need to remove #1 which is easy enough (yes I have trim tools). But how does #2 come off? I'm expecting this is one of the B&O speakers and the last thing I want to do is break something. What other pieces do I need to remove?
Help me Obi-Wan Kenobi, you're my only hope.
BuckStrickland
West Virginia
You don't have to completely remove one, and two just pulls out. It's a speaker, and does have a wire w/ a clip, and it's all on there pretty tight, but nothing you're going to rip apart unless you have herculean strength.
Beerman
Minnesota
2026 ST
Thanks guys. I'm still waiting for the P3 to be delivered, will repost here if I need any further advice and likely post some pics for others.
Virginia
2026 ST
Following this as I came here to post the same question.
Nashville Tn
if you are hooking up the continental ethanol sensor let me know where you went through firewall with signal wire. i have my fuel lines and sensor in place just havent connected to anything yet or installed the P3 but ran into same thing seeing what all needs removed to get to same access .
Beerman
Minnesota
2026 ST
I'm not doing the Ethanol sensor yet, but I believe @UNBROKEN did. Still waiting for my P3 to ship, just trying to get ahead of the install process at this point.
